Ok thanks. Humour me a bit, I've only ever changed the coolant by dropping it all out, and then filled and bled. How would you flush, and with what?
Water?
I've always flushed by dropping the coolant, refilling with water + BARS coolant/radiator flush (following the guidelines on the product itself), and then re-drain and finally re-fill as per normal.
Classic Rypt.
The output of the engine has sweet FA to do with chemical incompatabilty.
A Super output engine would be running pretty much water anyway![]()
A bog standard engine is designed to be run with most types of coolant, such as the cheap Tesco jobbies. And a Golf falls in this category.
Classic Jonnycoupe doing a Fox and missing the point.
A high output engine may be using some special alloy which may not react well to certain coolant mixtures, it may also perform better with different coolants that have different properties.
^^ LOLZ, what engine has he got in his Golf then?
Given that you don't know i'm going to assume you class the 1.8T engine as a bog standard engine, which as already stated has issues with mixing coolant types.
Except for generally if you mix coolants that are similar to each other nothing happens, and I would think a G11 would be pretty close to a G12 (else it would have a different naming)If you mixed the coolant in anything you could have issues
Assumption is the mother of all **** ups.
Get a clue before you give advice please![]()
Right, so should we now not mix BP Ultimate with Shell Premium (or w/e the naming is) fuel? After all, we all assume that since they are similar they will work fine.
Things that are nothing alike should NOT be named similar.
It should be G11 and A12 or smth
How about DOT 4 and DOT 5 brake fluid?
Go down the clue shop and take your chequebook.
Perhaps you need a clue book, since you can mix DOT brake fluids generally (so running a 3+4 mix in a car that usually uses 4 would work fine)
No, you need the chequebook and clue purchase, DOT4 and DOT5 are completely different.
One being Glycol and one Silicone.
I did say DOT 4 and DOT 3 in my post ... which CAN be mixed
