Which cases just 'work' for watercooling?
27 Nov 2009
Maidstone, Kent
Basically, this thread is designed for a list of cases that can be set-up (without too much difficulty) to take at least a 120.3 radiator, without missing features too much. So if you lose all the drive bays for example, it's not really a good watercooling case.
Key:
Works straight from the box
Requires modification (no more difficult than cutting fan holes)
Requires significant modification (removal of HDD cages, significant panel modding etc)
Current list:
Coolermaster CM Storm Sniper - thick rads may interfere with RAM slots. Uses 5.25" space
Coolermaster COSMOS 1000
Coolermaster COSMOS PURE
Coolermaster COSMOS S
Coolermaster HAF 932
Coolermaster ATCS 840
Coolermaster HAF X
Corsair 700D
Corsair 800D
Danger Den Tower 21 Series (inc wide)
Danger Den Tower 26 Series (inc wide)
Danger Den Tower 29 Series (inc wide)
Lian Li A70 - though only with an optional or modded top panel (triple 120 in roof, dual in front if HDD bays removed)
Lian Li A71 - though only with an optional or modded top panel (triple 120 in roof, dual in front if HDD bays removed)
Lian Li PC-P80 - requires top panel modding if HDD bays are to be preserved - space on floor for slimmer radiator - requires cutting
Lian Li PC-X500 - intakes hot air, so not recommended - requires HDD bay removal, which is riveted, though more are available in the roof - presents certain GPU length issues
Lian Li PC-X900 - intakes hot air, so not recommended - requires HDD bay removal, though more are available in the roof - presents certain GPU length issues
Lian Li PC-X2000 - intakes hot air, so not recommended - requires HDD bay removal and the GPU support strut, though more are available in the roof - presents certain GPU length issues
Lian Li V2000 - requires side panel cutting
Lian Li V2120 - requires new top panel or modding
Mountain Mods Ascension
Mountain Mods Monticle 24
Mountain Mods Pinnacle series
Mountain Mods U2-UFO
Silverstone FT02 - intakes hot air, so not recommended - presents certain GPU length issues
Silverstone RV02 - intakes hot air, so not recommended - presents certain GPU length issues
Silverstone TJ07
Silverstone TJ11
XSPC H1
XSPC H2
Silverstone RVO2
Whack out the 180mm fans & mountings and your have a grand canyon to fill with anything up to 360/420. An entire loop can be pulled out without any draining needed, aswell. You could allso fit a full-fat 120mm rad at the exhaust fan but could increase idle/load case temps.
A great case for £100-115
F.y.i , not my build, its from the Evga usa forums :). Planning on doing somthing similar as i have the same case :P
Oh yeah, forgot about the RV02/FT02.
I'd seen the ATCS 840 too, just thought it was a dual in the roof.
RV02 looks to be the cheapest 'watercooling-friendly' case so far...
This is purely out of interest at the moment, as I doubt I'll be able to afford a new case now...
Don't forget the HAF X or HAF 932 both fit a 360 in the top, and a 140/120 on the back and you can fit 2 240's on the side of the 932, and I think also on the X.
Love my V2000, thing is epically huge. Have a 420 in the bottom bit and space for a 360 in the roof :D
some that people may not usually see.
Mountain mods pinacle
Mountain mods ascension/u2ufo
Danger den Black series/double wide
Do bench tables count?
Updated OP. I'd say Bench Tables probably don't count - simply because they're not really a case as such...
Hopefully this could be made into a sticky to help others who want to find a nice easy list of good watercooling cases.
Great thread - I've been looking at grabbing a new case and putting my new w/c loop back together. It's frustrating that good w/c cases are so big though! Would be great if you could fit a 120.2 into a midi-tower!
That's one vibrant PSU there RJC.
Have to say though, everyone knows the 800D and 700D are great for watercooling, hence this thread... :D
Coolermaster's 690 II range allows for a 120.2 in the roof, enough space for a pump/res at the bottom, and a 120.1 at the back - so I think that'd be your best bet Reflux.
Or one of the Lian Li PC-P50s or Lancools.
Well of course w3bbo - love Mountain Mods cases, but couldn't afford one by a long shot...
I enjoyed reading through your build log on that one, really excellent results.
Silverstone RVO2
wow just 115...thats cheap...can u gime the link
