Troll type?!? You mean my post isn't good enough for the full troll award?
*must try harder*
And what OS are you using? Driver Sweeper was designed and programmed long before Windows 7 came about yes it was a good app when we all had XP and wanted to swap between ATI and Nvidia or vice versa but with W7 it causes more problems then it solves and the fact your having problems updating drivers simply reinforces that point.
I don't mean to have a go at people but even though know one will admit to it especially after a failed driver installation but a lot of you constantly tamper around with both the hardware and software of your video cards - hacked BIOS flashes so you can get voltage tweak springs to mind, registry hacks, overclocking, 3rd party apps to over ride default driver settings just because the idle clocks are bit high, running driver sweeper. I don't do any of this BS and I don't get any problems, coincidence? Now put that aside how many of you have installed beta drivers? How many of you have some half baked 3rd party utilities/shareware/beta/alpha software installed or running in the background? Yes everyone’s computers different but I’d wager most of the problems listed on here are down to the user and not the AMD/ATI.
