MDF sometimes comes pre-primed, but if yours isn't then it is important to prime the surface before painting. You can use any number of water-based primers, such as an emulsion paint or a proprietary acrylic primer. This base-coat of primer will help give the top coat a truer shade and will prevent it from being affected by the color of the MDF. The primer will also prevent MDF's tendency to result in a blotchy, uneven finish due to its porous surface.
Tis important in my experience, or the paint will just absorb into the MDF.
One coat of primer, then undercoat, the top coat is what I would do!
*awaits correction*
This is what i would normally prime mdf with as well, also used acrylic wood primer but emulsion is handy as we buy it in large buckets for contracts.i'm a decorator.just use a watered down white emulsion for the primer.it will soak into the mdf and provide a good key for the top paint.just sand in between coats
Then id suggest emulsion, thin it a bit to help application, particularly on the edges as mdf soaks paint like a sponge, then apply 2-3 coats of your chosen finish colour, lightly sanding between coats.Thanks for all the advice/info.
The final finish will be matt. Not sure what colour yet but it'll be a slightly different shade to the wall it's mounted on.
I always use some watered down PVA.
this. wasting ur time putting loads of layers of paint on. mix pva with water till you have a milky texture and you're onto a winner. give the edges(end grain so to speak) a few coats as this part is less dense and even more absorbant!
I didn't think emulsion stuck to pva or I'm I thinking of something else?
MDF drinks paint
For modelmaking I seal it with a 2-part sealer that the paint won't get through.
