Whats the score with the VRM things on these cards, read so much i have no idea if its meant to have a cooler or not or if it even matters... ??
This is what the palit sonic looked like in reviews:
http://www.techspot.com/review/299-palit-inno3d-geforce-gtx-460/page4.html
The final end product had no VRM coler or even in some cases copper heatpipes on the cooler. Some people are getting the heatsink with copper heatpipes, other people are just getting a slab of bare metal.
The VRM coolers on them increase max overclocks by a bit, mine went up from 875 to 890 Mhz stable without artifacts after adding some VRM sinks, however even the stock card overclock of 875 Mhz for two MSIs was higher than what I've seen the Palit capable of.
The VRM cooler isnt the only issue. The issue is potentially getting the cooler with no heatpipes and maybe also getting whining fan noise.
They seem to have fixed the fan noise with a new bios, so you would already need to bios update them if you have problems with that.
My only concern is why buy the palit right now when the Asus is £165 and better? Go for the better card, especially when it is cheaper.
Well, the Asus is only £2 more than the palit now, still definately worth getting instead.
Just also read that this card is very loud and may require a bios flash..... Wish i had gone for the 5850 now.. Think i will stop reading and see what its like tomorrow...
Why a 5850? Just remember that its ONLY the Palit version so far that has been having these problems. Any of the custom cooled 460s would be fine without any noise issues, plus you are guaranteed a great cooler and decent overclocks.
