Test Intel Turbo Boost working?
10 Apr 2004
Is there a certain way of testing my W3520 (i7 920) that it's going up to 2.93ghz correctly as Intel says it should?
The Intel Widget in W7 says it only ever hits 2.8!!!
I've loaded a single core using prime but that didn't do it.
All 4 cores go up to 2.8ghz fine, just one core won't hit 2.93 :(
Load temps ~60C using realtemp
Cheers
Do you have any load at all on the other cores, if 2 or more cores are doing pretty much any work at all, then all 4 cores will be limited to a 21 multi (or 2.8ghz)
Nope, this is at system 'idle'.
I was going to limit the system to just two cores (Core 0 and Core 1 - HT) to see if it will clock itself up.
I think this single core turbo boost is a absolute waste of time, when is only one core ever doing anything now-a-days!?
windows swaps load between the cores so its a waste of a feature
on my 1055t thats suposed to be able to clock 3 cores to 800mhz and the other 3 to 3.3ghz it never works.
download coretemp and you can monitor the cores in realtime for me turbo core kicks in for a fraction of a second then clocks back down every few seconds :| even if i manually set every process infinity thats using any cpu onto the same core
On my board it depends on what bios I use (on my old i7 860), if I use 1.4 it works flawlessly sometimes anything newer than that it just doesn't work.
