[TW]Fox;17248404 said:Well which, it cant be both![]()
Ah, 8 button OBC and the older wheel.
Dual zone climate though, which is always good.
Was just interested to see what you'd managed to pick up.Sounds like you got a better one that me...but then I knew I wasn't buying a minter.
The ASC is proving to be great fun in this weather as I often find myself playing a game of 'will the ASC light come on' when taking corners a little bit quick. So far I've only set it off on our lane (gravel) and by accidentally putting a rear wheel through a patch of mud at the side of the road.
You account should be activated now, just had a PM.![]()
26th April 97, which is the 96-97 model year, unless BMW model years dont run from September 96 to August 97?
Year of Manufacture is shown as 1997, which presumeably was between Jan 1st and April 25th so you can decide which is the actual model year if pedantry worries you that much![]()
I play a better game called, "start the engine and turn DSC off", I play it every time I get in the car.
But then I have the pretty light on ALL the time!![]()
Yes, it's the man light. If it's off, you're a pansy.![]()
[TW]Fox;17249944 said:I can see how its totally worth disabling DSC for a trip to Tesco. You are, as it would seem, da man.
As DSC and ASC differ I'm more of a man for having a lesser system.![]()
Fair enough, just the picture makes it look like the damage could be nasty and I understand these things to be quite flimsy. I have to remove mine at some point as one of the seals is a bit broken, not looking forward to it.
Oh and...post up more info about the car.![]()
e36coupe.com said:side skirts
1 rivet in the arch area front and back,6 underneath,pull side skirt off,take old clips out and replace with new ones coz its guarenteed that they will break if you try to put them back onto old clips.
e36coupe.com said:Mate there are clips on either end of the skirt, take those off, then under the car you will see more clips, take them off. You can just pull the skirt off then., breaking clips as you go. Great fun.
I took the hint and decided not to use my Oc/UK ID there.....R65466516+1351665elleventybillionp) I've PMed a mod, so hopefully it'll be sorted.
