It's as safe as the Titanic.![]()
to be honest the only reason you could loose your machine to watercooling is by doing a shoddy job setting it up right, skimping on needed steps like testing for leaks, using hose clips, etc. do all of those things and watercooling is as safe as breathing.![]()
It's nothing to be concerned about if you follow the correct steps.
Dont wear shoes then when you go near your computer and the floor is wet, start worrying.
It's safe mate, the fluid used is made to not damage your computer.. I know first hand it don't as mine leaked xD.. if it does just dry with toilet paper or something and use a hair dryer.
