My guess is you will be a lot happier with them than Fox is with your choice xD
This made me chuckle
This made me chuckle![]()
[TW]Fox;17258144 said:I'm more referring to the width of the tyre - and the 17's on the E46 are only 10mm narrower so have similar benefits.
My point being why buy a car with plenty of compromises made in the name of performance only to then fit cheap tyres to it etc? Why not just buy a car in the first place without these compromises having been made if they are not important to you? You'll save a load of money for a start.
Keep calm![]()
I am and indeed the rest of what you said was correct, buy the best you can afford.
[TW]Fox;17258213 said:So if I go and buy some 20 inch wheels such that the best tyre I can then afford to put on them are made by Wan Li, thats totally ok, and not at all indicative that perhaps buying 20 inch wheels or a car with them fitted was perhaps not a sterling idea?
I'm so bad at this making a withdrawl from an argument thing
Still, he's bought his tyres now so we are free to have a big tyre fight for the rest of the afternoon![]()
No its a bad idea as you well know, but even though you and i might stump up the extra for a super sonic set of tyres, not everyone can.
[TW]Fox;17258193 said:I cannot be bothered to argue with you if you are going to start putting words into my mouth. Nowhere in this thread have I called anyone an 'idiot' and I'm not prepared to start a pathetic slanging match.
I've made my point perfectly clear, and that is that I don't see the point in buying a comparatively expensive car and then cheaping out on matters to do with running it. £100 a corner for rear tyres on an E46 Sport, I was suprised you could even buy anything that wasn't a Linglong for that. a PS3 is almost £200 in this size, even the Potenzas which are amongst the cheaper premium tyres are £162 before fitting. If you think sub £100 tyres are going to be as good, then, well thats your opinion and you are entitled to it. The lower down the range you get the less a tyre is a considered blend of performance, economy, grip and life and more it simply becomes a round black thing to appeal to those who simply want 'some tyre'.
So then the same could be argued for premium tyres when you don't require the extra performance of a premium brand?
Double Standards much?
[TW]Fox;17258237 said:I cant afford good tyres and maintenance on a Porsche 911.
So there isnt one parked outside.
Besides, a set of 452's is hardly expensive!
It's not so much a question of performance, but a question of safety.
[TW]Fox;17258264 said:What I've seen about 912's suggest they are not badly suited to lighter cars, but for heavier cars, there are better choices - of which the 452 is one. The fact Falken offer the 452 as well, higher in the range, suggests its probably a better tyre if nothing else!
Actually Falken promotes the 912 as a tyre suitable for MPV's as they do specific versions with reinforced sidewalls for heavier cars, but I guess you knew that and took that into account when you read those internet articles right?
[TW]Fox;17258296 said:Like, you know, the 452. The one even Falken themselves are happy to claim is superior!
And they are only £2.80 extra per tyre in 255/35R18 size at Camskil.
I know which tyres I'd go for, and yes I've tried both.
