Hello, I am planning on Buying the Titan Kyrpt on Monday, but the only problem is i need it to be wireless and I'm not experienced enough to install a wireless PSI card. So i was wanting to know if the OcUK USB Adapter would work.
http://www.overclockers.co.uk/showproduct.php?prodid=NW-055-EX&tool=3
After i plug that into my PC, does it work like a PSI card? Or is it one of those Dongles you have to "Top-Up"? I am with Sky Broadband and have a "Sagem" Router that was supplied by sky, Would this USB adapter connect straight to the router and let me connect like a PSI card would, without extra top-up fees?
Or should i just suck it up and install a PCI card?
http://www.overclockers.co.uk/showproduct.php?prodid=NW-045-NG&groupid=46&catid=1597&subcat=
That one would connect to any router, wouldn't it?
Thanks a lot!
Thanks a lot!
