[TW]Fox;17258558 said:
I bet that in every given circumstance involving grip (ie aquaplaning, wet braking, dry braking, lateral grip, etc etc) the 452 will be superior to the 912. Thats the point. It's why it exists
Performance = grip.
Firstly, the 912 is a newer tyre than the 452, so some improvement in compound and technology is involved, I am sure in teh tyre that replaces the 452 that tech will improve the 452 by a similar amount.
Next aquaplaning has NO grip, no matter what the tyre, you are deluded if you think one offers more grip when aquaplaning.
What different tyres do is have a resistance to aquaplaning based on how much water they can clear, as a general rule of thumb, the tyre that can cut thru the water will have more resistance to aquaplaning, that involves using tread patterns that are sub optimal in the dry. This is one area where the 912 scores above the 452 which acts more like a sledge due it its far stiffer carcass and older symmetrical design, Additionally a harder compound is used in this case to stabilise the tread and how it cuts thru the water to minimise aquaplaning.
Dry grip, this involves putting as much rubber on the road as is possible and having that rubber as stable as possible, blocks moving around under cornering can have less feel and are sub optimal for driver feedback, but are far more forgiving on some road surfaces, this is where the 912 is inferior to the 452, as the 452 will use a softer compound and highly stable block pattern to maximise dry weather grip.
Stiffer Carcass, a stiff tyre gives more accurate feedback to the driver and also gives improved response to steering inputs, this is almost demanded by a performance driver and failure to deliver this leads to the driver feeling less involved. This however can be tiring over longer drives so is sub optimal for longer journeys over highway style roads. It can also be less forgiving on bumpy surfaces. The 452 is a stiffer tyre than the 912 and is designed to give more feedback to a performance driver, it gives best results on a smoother surface where its tread pattern maximises surface contact and minimises tyre deflection under hard cornering.
Essentially the 452 is a high performance "summer" tyre and the 912 is an "all season" tyre, as a result, the 452 excels in the dry and the 912 is an improvement in the wet.
I could go on, but I really cannot be bothered, if you truely believe that 452's are better in every circumstance than 912's then I will never convince you and I don't even care to try, for those with a less closed mind, the above information may help you decide whether you want a good all round tyre with less than maximum dry grip or an ultimate grip dry weather tyre with some wet compromise for a similar price.
