For PlayTV owners
PlayTV takes only 1gb per hour for recordings.
Does the ps3 have a hard drive limit, will the Toshiba MK7559GSXP 750GB 2.5" even be recognized at this capacity?
I've not heard of a HDD limit but it's possible. I have seen people stick 660 and 750s in so they should be fine. I am sure I saw someone with a 1TB drive in a PS3 too. No-one knows any specifics about the File system they use but it seems it has support for large drives, so I'd say you should be safe.
Personally, I wouldn't advocate huge drives in the PS3. Simply because that's a whole lot of data to lose if your PS3 busts - when you insert a HDD into a different PS3, it's formatted. ;) If you want to keep stuff, copy it to an external USB HDD instead.
Thats partially incorrect - the BBCs quality/compression usually means its more like 1.6-1.8Gb per hour...
If its taller than 9.5mm IIRC then it wont fit, so that one should be fine - dont think theres too much information regards the PS3s file system and how large a volume/HDD can be - Id be surprised if it doesnt support 48bit LBA though...
ps3ud0 :cool:
your right :) it's channel dependent on the size of the file,but most of my programs are no more than 1gb-1.2gb in size per hour. bbc and channel 4 seem to be around 0.8 for 30min.
PlayTV records the raw streams so it depends on what the channel's bitrate is. BBC use highest bitrates of all, I think.
that could explain why i though one recording had 2gigs under it. one thing i love is the fast forwarding, its so responsive unlike pvrs and Dvd recorders.
i think your safe, as it just says your using play tv so you can watch your soft porn without worry.
* The final new feature coming to PlayTV is designed to give you some added inspiration with ‘Community Favourites’. This feature lets you see what your friends and the PSN Community are watching and enjoying. So if you’re ever stuck for something to watch then just check out what everyone else is watching. (Not available in Australia)
