I did a fresh windows install and started with version 10.4 as 10.8 wasnt out, basically your saying I need to reinstall windows everytime I want to update my graphics drivers??
Really doesnt sound right, in terms of testing the PSU under load No I dont have the ability to do that, I used a power supply tester which means I have to disconnect the sockets from the board to test them, I dont have a voltage meter and I cant afford to buy one just to check one power supply.
If it was a power issue I would expect to see issues with my overclock and other devices in the system as I have experience no other power issues and I can rack up 100% load on CPU and graphics card with 0 errors or random shutdowns or crashes with particular drivers installed it does seem to be software, I only get problems when i try to change drivers if I stick with 10.4 the system is solid as a rock.
Honestly I find it pretty condescending when everyone blames the user rather than the software, its clear that there are issues with the drivers or there would not be so many people bitching about it everywhere, I am not a n00b to this I have been building systems since I was 14 years old (thats 16 years (showing my age I know) and I can troubleshoot my way through a problem.
Everytime I have an issue its only when I choose to change drivers, basically the added features and bug fixes are un-available to me and countless others because of some esoteric hardware configuration that we have that causes a problem with these graphics cards on certain systems with certain hardware configurations which no one can seem to identify or suggest which bit of hardware it is that causes the issue.
Personally I am thinking of trying 32bit windows again to see if its a 64bit issue which is what I think it could be, it does seem truly random though as some people have no issues and others have loads
I rolled back to 10.4 and everything runs fine and dandy
Then stick with 10.4![]()
Do more recent drivers not have fixes and better performance in some titles like BC2.
I thought 10.4 brought about the quick loading in BC2?
10.1 - worked but issues
10.2 - worked but issues
10.3 - BSOD
10.4 - stable and best drivers so far trouble free apart from known bugs
10.5 - cant install at all
10.6 - works but crash to desktop on games
10.7 - same as above
10.8 - BSOD, crash to desktop
All drivers show the "decrease in screen brightness" issue if I change from the driver I first installed the screen just goes dim and washed out
Yeah well 10.4 works but BFBC2 is slow loading and there are some gains on performance on crossfire with certain games so it would be nice to be able to use them I just hope that 10.9 and 11.0 are going to improve the poor run I have had, it would be nice to get one updated driver release that works for me![]()
Then just use 10.4 with 10.8 crossfire profiles for now.
