- 8 Jan 2009
- Northern Ireland
Can you get the full version of this OS. Reason being, this advert HERE, says upgrade.
A big thankyou. I'll get that on order tomorrow.Concorde Rules Technically it's an upgrade but actually it's a full disk.
xarr
Just remember it doesn't include iLife so you need to use a time machine backup, your original disk or a copy of iLife to reinstall it. Apple also does a box set with iWork, iLife and Snow Leopard for £132.
Iceman
I have a brand new copy of snow leopard which is unused. Mail me if you want to and we can talk about it.
You can use it with a clean install.
IS the OS not free when you buy a machine then you can get updates for free? I am learning the Apple Mac world as I just have got a Mackbook Pro.
ah I see, this is the way windows should have gone. Thanks for the info.
Are you saying, that if want to do a clean install, I need iLife.![]()
Note: You will no longer have iLife on your computer. However, you can use the same discs that came with your computer to install iLife. Eject Snow Leopard, and insert the first disc that came with your computer. It should say something like Macbook Install Disc: 1. After Snow Leopard automatically detects the disc and opens the window, you will see an option to install bundled applications only. Double click this icon, type in your password and let it install. Half way through, it will ask you to insert the 2nd disc to continue. Insert the 2nd disc that came with your computer and let the installation finish.
