Azalia Intel High Def Audio to Sound Card or Mobo
Kua
Kua
21 Jul 2008
Lancaster
Hi
Does anyone know how to connect this (from the headphone port at the top of my Thermaltake case)...
IMG_4642 by MathMcC, on Flickr
...to this (my sound card). I'm not even sure what these two ports are called so couldn't search for a converter.
IMG_4645 by MathMcC, on Flickr
or even my mobo perhaps (couldn't find a port for it on there either).
Thanks!
I don't think Creative support front panel headers. You'll have to:
1. Hack together your own adapter.
2. Get a sound card which does. There doesn't seem to be a front-panel connector on your board, and, even if there was, your board seems to use an old AC97 chip which uses the old pinout.
