HTC TYTN II
dsb
dsb
31 Jul 2006
What is the upgrade from HTC from the TYTN II with a slide out keyboard that can be purchased, from online shops.
Its for my insurance coy.
A bit of a wide open question to be honest fella.
Anything iPhone, Android related will be an upgrade by today's standards.
What are your requirements, what are the insurance companies requirements? Does it have to be HTC for example?
And what do you mean be coy? Are you fleecing them or is it a genuine claim?
No its a genuine claim, i have a TYTN II which i dropped whilst getting out the car then stood on it, not happy as it has 100s of numbers I use on the phone, I use it as a sat nav, blue-tooth the lot. They just want the model up from the TYTN II i would say HTC to be fair, it so they can make sure i get a fair price. It was factory unlocked bought out of contract so will need similar set up as that.
A kaiser is coming up on 3 years old now, it's worth is pretty low relative to the current generation of phones but in it's day it was high end so lets stick with that - assuming you need a GSM as you said you got it unlocked then you should be looking at a HTC Desire, their current champion handset or the HD2.
It's worth noting those phones are NOTHING alike - the HD2 is windows, the Desire is android.
