- 18 Oct 2005
Got the EVGA GTX460 1GB for our HTPC, not realising it was an exhaust design. The rest of the case is so quiet that this is the only thing that can be heard, which has a sort of high pitched bearing whine at the lowest setting of 40%. It's too loud and the fan wont go lower that this.
Will the reference design cooled cards be quieter than this? Is the MSI one with it's mad fan really even quieter than that? (or is it louder at idle and quieter at load).
Basically I need the card (460 1gb) that will be quietest at idle, or at least on that is very quiet. There seems to be some debate over which this is. Any advice from current owners or others that have done the same 'hunt' would be appreciated.
