rFactor F1
Well this thread has certainly drawn me in. I have got rfactor laying around somewhere.
Any know whats up with rfactorcentral? I don't seem to be able to create an account, I keeps sending me back to the registration page after I click register. No errors come up either :\
This thread as drawn me too. i have rfactor lying aroudn somewhere along with my g25 wheel collecting dust.
what times do you guys normal race?
what mods do i need to install?
Check out http://www.log1k.co.uk/ for all of the tracks and mods you need to play.
Erm there isn't any precise time (maybe something we should set) but anytime after 7pm seems to be about the time people come on.
Hmm, Ive tried both IE and Firefox and both do the same thing. I was after the HDR addon mainly but the F1 hud as well.
Here are some of the download links, not sure which ones you are looking for :p
TV HUD download links:
TVStyle 09+91_upgrade.rar
http://www.megaupload.com/?d=Q7HK6LJ1
Tvstyle2009.zip
http://www.megaupload.com/?d=L3667PQG
HDR (not sure if that link will work, also I know it says gtasa but it is for rfactor ;))
http://74.221.231.89/enbseries_gtasa_v0074e.zip
Tvstyle2009.zip
Ive just started the 2010 version from Prunn.
http://prunn.xtreemhost.com/rfactor/ Click the image at the top of the page for a video. Its also a quick lap of Spa.
Everything you need to get on the server should be on http://www.log1k.co.uk/
Look forward to seeing you on. I'm usually on from 8pm and will be on later. :D
Good racing last night guys. ;)
Edit: A more specific response to which mods you need is: F1 2010PE + The patch to 2.0
Guys why are we using this mod? I find that the graphics and engine sounds are much better on WCP 2009?
Funny you mention this, I completely agree with you! I've made this known before. But other users tend to steer towards 2010 PE.
Try deleting your TryMedia folder. The game will Re-create the folder next time you load it up. Or so I've just read. Back up the folder first in case it fails.
Location: "C:\ProgramData\Trymedia" Its a hidden folder BTW.
EDIT: The TryMedia folder is the folder that holds your license I believe. Hopefully it should re-set it and let you enter the code.
Thanks for your help but I couldn't find that folder so im going to try installing the download (once its finished) rather than installing the disk that came with the g27 wheel.
PE 2010 V2 isn't the best, but it does have new tyre physics which makes them go off very quickly. After a 4 lap run your super softs are dead..
If the group wishes for FSONE 2009 collectivly then of course we will change. Makes no odds to me at all.
Okay, i'm struggling to get along with this mod, the FFB is all over the place, the graphics aren't anything special yet it runs terribly and the car doesn't feel good at all, far too easy to drive, you have to be digital to get a slide going, and somehow it feels like the front and back of the car aren't connected to each other. Also the UI and menu music it installs are terrible, but that can be fixed.
It is obviously nice having the 2010 cars, but it isn't worth the drop in quality from FSone 2009 just for the new cars, FSOne is better in every way IMO.
WCP 2009 is good and i wouldn't mind this, but FSOne is my first choice.
