Splitting Lan line with one Lan cable
7 Feb 2004
I was wondering if it is possible to split a lan cable line into two lan cables?
I have one lan cable down stairs but have two devices. Can I just buy a switch that would do that?
Thanks
You need a hub or a switch, which will work just fine. What you can't do though is just try splicing two cables together.
You could buy a cheap switch and put it downstairs, that'll work. The other thing to do is split the lan cable (but you'd be limited to 100mb on each link) which is easy enough to do as Cat5 contains four pairs, where only two pairs are used on a 100mb link.
Easiest way is to use a switch at the other end.
There is another option, 100m/b ethernet (not gigabit) only uses half of the wires in cat5. So you can fit "cat 5 economisers" at BOTH ends.
Not necessarily, the connection might be for other devices that don't support 1Gb, media players or games consoles etc.
It would be best to employ a small switch at the end of the cable, but the option of splitting it is there, at least.
I have this, one to run my modem to the router in the comms cabinet, the other to send it back again for a 10/100 switch :D.
You can always get a splitter if you have no sockets spare
We have used this a few times in non priority bandwidth parts of the network, never had a problem with them.
