- 5 Jul 2007
- London
I used to use wood blocks on my old merc. Then had to use my small jack to get it up, then put the big jack underneath. The chassis rails were pretty low.
First thing: that's not low.
Now for something constructive. Go to Screwfix or Machine Mart and get a cheap scissor jack. They are about 2.5" tall when all the way down. You can put it under a sill or wherever and lift it high enough to get the trolley jack underneath.
I'm confused. How do you jack up with a small and then replace with a big jack? Wouldn't the small jack be using the jacking point?
I assume jonny meant my car, which certainly does not look low in that picture. It's low enough that the cross member sometime scrapes on heavily cambered rods. Maybe it's broken.Imo its low, its only got 16 inch wheels with low profile tyres. hence the fairly large arch gap. You'd struggle to get a coke can under the chassis rail. let alone the jacking rubber.
This one seems a little too cheap...
http://cgi.ebay.co.uk/Liftmaster-Lo...-/270629243814?pt=UK_Lifting_Moving_Equipment
Even a racing jack wouldn't clear my old car, I had to stage 1" thick planks of wood gradually over half the length of my drive (that was a pain to keep aligned with the wheels!) and then use the racing jack:
wow, got any more pictures/specs?
awesomeness...
