Assuming your case take it this motherboard.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-410-AS&groupid=701&catid=5&subcat=1782
PSU: http://www.overclockers.co.uk/showproduct.php?prodid=CA-032-BQ&groupid=701&catid=123&subcat=1083
not bad.
but this CPU is faster and cheaper
www.overclockers.co.uk/showproduct.php?prodid=CP-268-AM&groupid=701&catid=6&subcat=803
Thanks for the input, care to suggest a mobo?![]()
as above.
and that bequiet psu is more power, same price, higher quality, but not modular
Extra 100w and BEQuiet are excellent PSU.
Akasa Venom looks nice, depends if black & yellow is your thing.
H50-1 Also nice looking, the H70 is better but requires quite a bit of space in your case.
Any one else care to have a look?
Hello ellingham,
couple of points . . . firstly have you considered getting a uATX/IGP enabled board instead of a older ATX? . . . I say this because these days (2010) most people don't really need anything bigger "unless" running a multiple GPU set-up or have a stack of legacy PCI cards they wanna use? . . . I switched all my *non* multiple GPU builds to uATX over a year ago and its working out well!
Firstly i have never built a pc and am very new to this but is the jist of what your saying, get the uTAX board and it will be easier to fit into my case, it won't affect me as i am not using it to run mutiple GPU's and so on...
The memory you selected is nice but just in case you didn't know DDR3 is pretty cool running and doesn't really require these heatsink style designs unless you are overVolting and overclocking them . . under standard operation in a case with some airflow the standard jacket memory run just fine, I think mostly its a marketing thing where people go "nice heatsinks" etc. . . now some people may say "well its the same price so why not?" . . . . the only reason I would avoid the memory with the heatsink design is that they sometimes clash with a 3rd party CPU "tower" HSF . . . if you are only using the stock cooler then this is a moot point and the "chunky" memory works fine but if in the future you want to add a big mama HSF then you may have to use the memory slots furthest away from the CPU socket . . .
I see what you're saying but i picked that ram siply because it was on offer
SATA 6Gb/s? i do not understand what this means
Next up is your choice of GPU, the Radeon HD 4870 512MB is a nice card but its getting a bit long in the tooth now, having 512MB of graphics memory is fine for lower res gaming but starts to lag a little with modern games at high res like 1920x1080 etc . . . what res is your display? . . . the other thing is that card runs quite hot and eats more power than a newer card . . it also lacks the newer DX 11.0 technology which "may" be something you regret . . .
If you are unsure what graphics card you need and you don't need the full sized ATX board then a possible route forward would be to buy a uATX board and use the IGP for the moment and either hunt down a used HD 5770 or perhaps save a bit more money up for a 1GB/DX11 GPU . . . I guess this depends on what games you play, what O/S you use and your gaming screen res?
I have not chose a screen yet, but i see what you mean. Make a build now and then wait untill i have the cash for a top of the line GPU.
Lastly, there is nothing wrong at all with that OCZ PSU, modular is the way forward and 500 watts is "more" than enough power for that build . . . even if you went with the older power hungry HD 4870 GPU your max power-pull would be about 350 watts . . . it's all well and good some people saying a PSU with more power is better but if your unlikely to use it why bother? . . . a PSU needs to run at approx 75% capacity to be efficient and as far as I know it actually works against you to have a too powerful PSU running at minimum load i.e. it will draw more power from the wall (££) vs a more efficient running PSU . .
Taking all these points to a logical conclusion and assuming you play modern games at higher res under Windows 7 and intend to keep this system for a few years I would suggest you save up for a modern GPU and build the following system for the moment . . .
Take you time "considering" what I have said and I'm happy to politely discuss any of these points!![]()
That's fine, we are all nOOblings here!Firstly i have never built a pc and am very new to this
I was asking you if you had considered it . . . from what you have stated he answer is no! . . . thats good!is the jist of what your saying, get the uTAX board and it will be easier to fit into my case, it won't affect me as i am not using it to run mutiple GPU's and so on...
No probs, you picked good ram and the proviso about it clashing with a 3rd party Tower heatsink may not be relevant to you . . . it is the same as the memory I included in the spec above although its out-of-stock . . .see what you're saying but i picked that ram siply because it was on offer
It's SATA 3.0, the latest hard-disk technology . . . it's not a huge deal but it just helps the hard-disk get data to and from the system a "bit" faster albeit at a small price premium . . . it's not a night and day difference but its something to consider none the less . . . every little helps!SATA 6Gb/s? i do not understand what this means
Cool . . . is this for a standard computer scenario or? . . . lounge PC? . . . have you got one of those 40" LCD jobbies in your lounge etc? . . . basically describe the setting the PC will be installed in (bedroom, office etc) . . .I have not chose a screen yet
Kinda, if using the uATX board you ready to go . . . get the PC built and get a feel for it . . . then all you need to do is choose a modern 1GB DX.11 GPU and your gaming fun begins . . . doesn't have to be a "top of the line GPU" just the right GPU for your personal needs . . . if you only play older games or no games at all you may just be happy with the IGP . . .Make a build now and then wait untill i have the cash for a top of the line GPU.
P.S: please can you avoid quoting my whole post like you did above, also the red font doesn't show up propely on my display (hard to read), do what you want in this spec thread but if you do that in the main forums people may grumble! (I will!)
Thanks rickh!He chose the 1gb version of the 4870
No one has said otherwise? . . . however we are discussing options if thats ok? . . . or are you suggesting thats the only card he can choose?that card is excellent value at the moment
Maybe for you personally but depending on how long ellingham will own the card it "may" be handy . . . If buying a new GPU now and running Windows 7 I think DX11 is not something that can be disregarded . . . it would be wrong of anyone to condem something without a thorough investigation no?DX11 is a moot point
If thats true then thats good news, last time I checked it seemed otherwise so thanks for the heads up . . . I will set some time aside later to check through that link you kindly provided, thanks!80 Plus certified PSU's are efficient at 20%, 80% and 100%
Heh, there is no such thing as a "PC Gamer" . . . but there is such a thing as somebody who likes to play games a lot using a PCTo be honest i don't need to game straight away as i'm not even a pc gamer
That makes sense . . . the PC will offer you lots!i do want to branch out to the pc and see what it has to offer
Cool . . .The main thing is to get the pc up and running as i'm getting tired of using a laptop!
24" approx works well as a dedicated monitor . . . I've had one of the past several years . . . paid £600 back in the day . . . nice to see them selling now for £150 odd!i will be getting a monitor (hopefully a nice decent sized one)
Hmm, you know a lot of people are connecting their computers directly to the TV's now via HDMI . . . does your TV have HDMI?The pc will be in the lounge for now but seperate from the t.v but in the future it will be moving to my room probably.
Can't really fault it myself apart from its hot running and eats more power ££ than a Modern (Evergreen) GPU . . . the thing that "bugs" me the most about the HD 4870 is it's "idle" power consumption (££), sitting there watching a DVD or surfing the web it just consumes wayys to much power . . . if the PC is only turned on and off for gaming then this is indeed not relevant but if its gonna be switched on 8+ hours a day most of the week then the energy bills ££ will add up . . . you may not care about this but being an eco-nut I feel obliged to make the facts known . . . cool?
4870 uses 50w more than 5770 in idle & 100w more at load
British Gas (Electric): 9.842 pence per kWh (rate 2)
