Is there any thing I can do bent pins motherboard
I managed to find a jewellers who would fix the bent pins I had. They have the precision tools needed to do a job like this.
I have used a propelling pencil to straighten pins on processors, the ones with automatic leads, the finer the better, just remove the lead and place over the pin. Better than tweezers,
andy
andy
Not ever tried this, but sounds like it could work very well indeed. Have an internet cookie.
Sounds like a good idea, they're likely to have a steadier hand than the OP evidently has, no offence intended!
Best thing would maybe be to the return the board. Is it new?
You can't return that unless you can prove it was damaged when you got it or in transit. Any return would be refused under these circumstances unless the retailer is stupid.
I was planning to sell the motherboard but when packing it up I kept putting in the cpu protection cap on wrong, and i forced it in the wrong way hence the pins breaking, but i did do a bit of (2:1 putting my finger in trying to bend them back) lol
My mistake wasn't putting the chip in as I stated before was taking it out and putting the protective cap on
get a mechanical pencil as said above take lead out put the pin in where the lead would go and bend back slowly and carefully, have done it on older machines and they all work fine :)
andy
Good luck using this method on a skt1366. The pins aren't really pins any more.
