Sys Requirements
Processor Min: Intel Core 2 Quad 2.4Ghz, AMD Phenom X4 2.2Ghz (or Tri-core like AMD Phenom X3)
Ram Min: 3GB
Video Card for minimum playability: Geforce 8800 GTX / ATI HD 2600 Pro
Video Card for best results: Geforce 280 GTX / ATI HD 4800 or higher
Core 2 Duo are out of luck as are anyone less than 3GB
http://www.quartertothree.com/game-talk/showthread.php?t=47906&page=2
Better be amazing if it actually NEEDS 4 cores to run at all. Wander if amd and Intel have been involved in any sponsorship /tinfoil hat
- The game was unplayable on my system — a core 2 duo 6700, 267 ghz; 4 GB RAM (but effectively less, since running Win XP SP3); Geforce GTX 285 — all drivers up to date, I was getting under 10 fps.
DreamCatcher Games and JoWooD Entertainment say we can expect both PC and Xbox 360 playable demos for ArcaniA: Gothic 4 on September 24. Word is: "The demo comprises the first two hours of the game and shows the beginning tutorial level on Feshyr Island featuring selected quests. Fight off demons, hone your skills and prepare for a bloody battle fueled by vengeance.
From reading this badly translated websiteAbout optimizing hard to say something good, but there would be clinging to a crime - it's still a beta version, which supposedly is still improved.Na moim domowym sprzęcie (Core 2 Duo 3 GHz, 4 GB RAM, GeForce 9800 GT) nie dało się komfortowo grać. Arcania gubiła klatki, w rezultacie czego animacja była bardzo rwana i to niezależnie od ustawień graficznych.On my home equipment (Core 2 Duo 3 GHz, 4 GB RAM, GeForce 9800 GT) could not be comfortable to play. Arcania frame was lost as a result, animation was very torn, regardless of graphics settings.Dokładnie ten sam efekt można zaobserwować na filmach prezentujących polskie dialogi, które kilka dni temu udostępnił CD Projekt.Exactly the same effect can be seen in films featuring Polish dialogue, which a few days ago released CD project.
, it seems like don't get your hopes up on being a true gothic.
, hopefully it's just because it's beta
PC Recommended Requirements
- OS: Windows XP/Vista/7
- Processor: Intel Core I7 @ 3 GHz / AMD Phenom II x4 @ 3 GHz
- Memory: 4 GB RAM
- Graphics: GeForce GTX 295
- DirectX®: DirectX 9.0c or higher
- Hard Drive: 9 GB
- Sound: DirectX 8.1 compatible sound card
!PC Recommended Requirements
- Memory: 4 GB RAM
- Hard Drive: 9 GB
- OS: Windows XP / Vista
- CPU: Intel Pentium 4 3.2 GHz, AMD Athlon 3500+
- RAM: 1 GiByte (Windows XP), 1.5 GiByte (Windows Vista)
- Graphics card: Ati Radeon 1800XT, Shader Model 3, 256 MiByte or Nvidia Geforce 6800, Shader Model 3, 256 MiByte
- Hard drive: 10 GB + 600 MB virtual memory
