I've always done all my own servicing and repairs on car and bike. However, my current bike only has 6k miles on it and full dealer history so I am a slightly reluctant to let this slip.
While the bike is under warranty definitely get it serviced by a "authorised" garage. They will try to wriggle out of it if you don't
Is that a hard job mate? Never done it yet and I think I need to at least top up the fluid in these SRAD forks.
not really. make sure you clean it all up properly before you put it back together and don't mark the stanchions when youre hammering the bush in.
the hardest part if getting the bike stable enough to take the forks off.
be careful with calliper bolts though as the head can shear off so mega important you 'feel' for it as you're supposed to replace them every time you undo them.
You might also want to think about a centre stand if you don't have one or a padock stand, nothng is worse than working ona bike with just a side stand apart form a bike with no stand that is
	Lol dogbreath nice work, your garage looks like mine even down to the crap sliding door
 When I moved in the originals had rotted so badly you could have walked through them like wet tissue paper.
