Yeah I figured the same, but then I touch it and the thing is midly warm (not hot) plus it's making no sound to indicate it's constantly heating
An immersion heater would be silent, as it's like a kettle element in the water tank.
Well, from what you've described it sounds like an immersion heater, which will chew through electric.
Do you have a gas boiler? What kind of boiler? Or an immersion heater? Or what?
Wouldn't you hear it bubbling?
This is what it says on the tin:
"Telford Stainless Products"
"TEMPEST"
"Mains pressure domestic hot water cylinder"
No gas at all in the property
So you have an electric immersion heater. This is costing you £1000 PA. Turn it off![]()
Yes but I want to prove 100% without doubt that this is indeed the issue. That's why I'm gonna try and be scientific in my readers over the next few days
Im liasing with a different supplier on a similar issue atm, they REDUCED my direct debit instead of increasing it on the back of some meter readings as they accidently only looked at the Gas, and not the combined, thus making it seem I was massively in credit. This came to light when i moved out ~4 months later and i had a bill for £300 despite being told on previous bills i was in credit!
They're allowing me ot pay it back over 3 months but I'm pushing for a concession of some variety as gesture of good will, as it was definitely their mistake that caused me to be behind, not a lack of communication (ie not enough meter readings)
Tom.
PS we used 17 units per day of electricity averaged over 228 days, and that was with 3 people in a house. I had a plasma tv on a few hours a day, a PC on 24/7 and for about half of it a dual quad core xeon server on 24/7, and my "lodger" had similar (lcd tv and a dual p4 server iirc) so not very light users really.
Doesn't it have a control box like to set temperature and/or operating hours?
Seems a bit naff to just have something like that with an on/off switch.
Not that I can see, just has a mains plug. I suppose it's because it's electric based?
Being electric based has no bearing on how the heater is controlled.
Don't you have a timer in your kitchen or something? so you can regulate when the HW/ heating go on/ off? that's what most places have...
Nope nothing like that. If indeed it is the boiler causing the stupid amount of electricity usage I'll just switch it off and then only switch it on before I get ready, so I'd go from 24 hours usage down to about 1. Should help![]()
Where is the switch to heat your water located and what does it look like?
