Hi,
Has anyone got any experience overclocking (successfully) with this board?
I want to use if for a 3-way HD4890 Xfire set-up, but unless I can overclock the CPU I'm going to seriously bottleneck their performance.
I have a Q6600 G0 CPU, which I can get to 3.25GHz, this is far from stable though. But i don't mean the CPU, its the mobo that can't handle it.
First I had to backdate the BIOS to a earlier version, as the BIOS that shipped with my board claimed that a 266MHz CPU was 'not supported' and would be underclocked as a result!? (This only happened during OCing)
The board has all the features needed in the BIOS, it even comes with software for OCing in Windows, what its missing is the ability to behave itself once the FSB has been bumped up.
You will probably need to have used this board to help, but help would be very much appreciated.
Thanks,
Thanks,
