Guys, I've been reading the forums over the last couple of weeks as I'm trying to get my first build for 10 years off the ground. (The last 2 set-ups have been 2nd hand ones from work that were just too cheap to turn down, but nows the time to build what I want).
Objectives are to play Civ 5 and SC2. With a view to be able to keep some components for when Civ 6 arrives in x number of years. I am budget conscious, but willing to spend good money on the right components. So here's my list so far;
CC700D - Corsair Obsidian Series 700D, Black, Alu Front Panel, Full Tower Case, 3 x 140mm fans, w/o PSU (cos it's gorgeous!)
Corsair 650 W TX PSU (Will this be enough juice to run crossfire etc in a few years time?)
MSI 870A-G54 AMD 870 AM3 Motherboard (cheap - I think future proof enough for a RAM and GPU upgrade in a year)
AMD Phenom II X4 Quad Core 955 CPU (Run in crossfire in a year or so)
4GB kit (2GBx2), 240-pin DIMM, DDR3 PC3-10600 memory module
Asus HD 5670 Graphics Card (add 2 more 2GB in a year or so)
1TB Hitachi Deskstar, 0F10383, 7K1000C SATA 3Gb/s, 7200rpm, 32MB Cache, 8.9 ms, NCQ, OEM
Sony AD-5240S-0B 24x DVDR 12xDVDDL DVDRW x8/-RWx6 SATA Black
AKASA AK-All-02BK Black LCD Displ, Card Reader,Temp Controlled Fan Controller, Audio, USB, Firewire,
Microsoft Windows 7 Home Premium 64 Bit, Single, - OEM
re-use existing monitor - AcerP223w Unfortunatley this won't snap to native res in DVI so I want to run it in VGA - unless you guys say this is a bad idea
re-use existing mouse (USB), keyboard (P/S2), and speakers.
Any comments appreciated.
Like I say, I have done this a few times but a long time ago (I can still remember getting a 50MB HDD that took up two 5 1/4" bays!)
My logic is the case and PSU will last for 5 - 10 years. The GPU and RAM can be upgraded in 1 year and the CPU in 2 (assuming AMD make their next chip [the AM4] backward compatible with the AM3 socket, like they did the AM3 into the AM2.
Cheers
Cheers
