Gents, Thanks for all your help. I really appreciate it, you've pointed out some blunders and helped me with some little pointers. Just to re-cap this is where I'm at:
CC700D - Corsair Obsidian Series 700D, Black, Alu Front Panel, Full Tower Case, 3 x 140mm fans, w/o PSU £145
850W Corsair CMPSU-850TXUK, ATX, 4x PCI-E/ 8x SATA, PS/2 PSU, 5 Year Warranty £105
re-use existing monitor - AcerP223w Unfortunatley this wont snap to native res in DVI so I want to run it in VGA - unless you guys say this is a bad idea
re-use existing mouse (USB) keyboard P/S2 and speakers
Microsoft Windows 7 Home Premium 64 Bit, Single, - retail £112
ASRock 890GX Extreme3 AMD 890GX (Socket AM3) DDR3 Motherboard £100
AMD Phenom II X4 Quad Core 955 CPU £112
4GB kit (2GBx2), 240-pin DIMM, DDR3 PC3-10600 memory module £72
1GB Asus HD 5770 CuCore, PCI-E 2.1(x16), 4800MHz GDDR5, GPU 850MHz, 800 Cores, DL DVI-I/ D-Sub/ HDMI £127
1TB Western Digital WD1002FAEX Caviar Black, SATA 6Gb/s, 7200rpm, 64MB Cache, 8 ms £68
Sony AD-5240S-0B 24x DVDR 12xDVDDL DVDRW x8/-RWx6 SATA Black £15
AKASA AK-All-02BK Black LCD Displ, Card Reader,Temp Controlled Fan Controller, Audio, USB, Firewire, £32
Total cost just shy of £900
Can keep the case, psu, monitor, peripherals, HDD and DVD R/W for ages. Can upgrade to 2 5770 in crossfire in 12months. Can up grade RAM if needs be. And can move up to a new board and chip when bulldozer is out and a good price.
Thanks
No doubt you'll here from me when I get stuck trying to get it all together!!
