- 19 Jul 2007
- notts , uk
if so what overclocks are you getting ? , also what temps are you getting ?
at stock mine runs at 22c and in games only 39C with a 50% fan level,
when overclocked to 900 chip and 1100 me i get in game 56c. The fan is quite noisey if it goes past 65%. I leave it on 55% and seems ok temp and noise level wise. The temps above are with the fan at 55%
i can only see 1 and it appears silver, thats if i am looking at the correct thing. silver block held on by push pins between the end of the card with the 6pin power blocks and the copper heat pipes?
10.8, best performance I've seen yet. Maybe you can see my result with this link? Who knows...
That's with everything at stock, I'm boring like that.![]()
Oh right, errmm, try this.
, seems with your cpu being at 3.4 and mine at 3.2 it makes your score a little higher than mine lol
