External watercooling rads/pumps?
30 Jan 2009
Aquilonem Londinensi
I remember a few years ago seeing a product (not sure if it was a prototype/concept/one off project) which was an external radiator with intergrated pump. Does anyone know what I'm on about?
It was about 1 1/2 - 2ft tall, cylindrical tower (bit phallus like :eek:) made from fins which were passively cooled. The pump was in the base of the unit and the pipes (in/out) ran from the base into the PC. Seemed like a good idea, just wondering if there is anything like that about?
Failing that, is there any external pump/rad cooling kits out there?
Swiftech Drive, rad,pump and res in one.
Yup, suppsed to be fine with a stock clocked processor but any overclocking would very quickly overwhelm it. They're made for silence, not performance.
Edit: that swiftech rad looks awesome for a no hassle setup!
Are those swiftechs for external mounting? Looks good. Would one of those be able to deal with a CPU like a Q6600 or i7) and a mildly overclocked 5850?
Yes and yes. The radiators are top quality, use Laing pumps and have a top-mounted fill hole. Check Swiftech's site for certified mounting orientations.
Thanks for the input guys, this is why this is the best harware forum on the net :)
The Swiftech stuff looks the job I think. Going to have a look about for CPU/GPU blocks now
Stupid question alert: :o Do the "full cover" 5850 blocks cover all the hot bits, like memory and power regulators etc? The last couple of air coolers I've used (inc. AC Twin Turbo) have left it up the user to adequately cool these bits...
Check on the manufacturers site but full cover usually means it'll cover the core, ram and vrm's.
The new swiftech edge kits look pretty good.
All Swiftech kit (with the notable exception of the badly-anodized GTX) has been good. I've used a lot of it over the years going back to some of their oldest heatsinks and have only ever had the one problem.
