Mate needs a pc, 1500€
What route should I go to for the best bang for buck, WITH NO or LITTLE overclocking ?
i3-i5-i7?
Amd ?
I'm out of touch with current hardware.
Pc needs to last at least 3 years, preferably younger, future proofing is important, ofc. it doesn't need to play games at high in 3 years but it should still easily meet minimum specs in 4+ years, or at least only need a new gpu at worst.
Don't need a full spec basically, I just want the bets bang for buck mobo-cpu-ram...
i3-i5-i7?
Amd ?
The 750 is a good choice and even better if you can get a good cooler and overclock. There is a socket change next year, but if you need a new pc now then go for it. I'd give amd a look first as well (955/965). Also the 470 is currently the best bang for buck gpu as well imo. Again, you could wait for the 6xxx series lol but if you need it now then go for it, you won't be disappointed!
) and AA), he currently has a small screen though will see how it goes on a 1080p screen.
