Asus Crosshair iv
13 Jul 2010
Hi guys im looking to build a pc using this motherboard but i would need 8GB of ram ive found this ram link below which is currently on offer from overclockers but if anyone knows of any ram that would better suit this motherboard then please say
http://www.overclockers.co.uk/showproduct.php?prodid=MY-288-CS&groupid=701&catid=8&subcat=
i would be eather using the AMD 965 or AMD 1090T not decided yet but i would like to be able to overclock it also i know that with 8GB of ram is makes it a little harder to get stable but its doable
Thanks
That RAM will not fit under a lot of air coolers.
I have that motherboard and the first RAM slot is right underneath my fan. I would not be able to fit anything taller than Corsair XMS3 or similar under it.
Yes that right any RAM cooler fan cannot fit on this mobo as I tried Corsair RAM cooler but cannot hold the other side of clip so no need to use - it would be fine without cooler fan as RAM using heatspreader -- I used 8GB OCZ "AMD Black Edition" DDR3-1600 that run much cooler..
Well I think that the ASUS Crosshair IV is a premium AM3 motherboard for those who appreciate the finer points of design and quality, it is one of the most high-end motherboards based on this new chipset, bringing all features high-end users could dream off: four PCI Express x16 slots, six SATA-600 ports, two USB 3.0 ports, gold-plated audio connectors, and more.
