Hey guys, have had my xfx 4890 for about 7-8 months since the first one I bought was DOA (sensing a trend here!) moved house 2 weeks ago, set the pc up last week and was having issues getting a signal on the monitor at all, might have been the dvi cable, after a new dvi and reseat of the card it seemed to have passed up that problem, put it on this morning and got bsod 4 times on windows 7 startup saying it could not load graphic drivers, another restate and the graphics were corrupted, blocky etc same as with the first card, artifacts all over the shop
After a few more restarts I had artifacts all over, again did a reseat of the card, moved it a bit further away from the wall (wasn't very close to it before!) restarted and all looked fine, ran 3dmark to try and give it a push, still fine, 6 hours later no graphical woes, all seeming ok.
Does this seem like a few unfortunate errors or a card on it's way out? Gave requested an RMA with OcUK which is to be done, but as I need the pc it's hard to go without it for 2 weeks on a maybe error, also had the bug a few days ago where the screen would go black fir 2 seconds anytime you used the windows aero in anyway, which seemed to fixed by using a default aero colour, instead of a custom one!
Thanks
Thanks
