GPU-Z -> Sensors tab -> VDDC Temps
can also keep record of GPU temperatures in a text document, so you can check after heavy gaming session.![]()
Your GPU needs to have thermal sensors on the VDDC(s) for this to work and if it has sensors then GPU-z will show it - the only exception to this is if they use proprietary monitoring hardware and afaik its only asus who have done this and only on some of their cards - which would then need smart doctor to monitor.
