Karcher
PA Foam lance
Werkstat Auto
Megs Hyper
Gloss It Gloss
Blackfire Gloss
Halfords Value for stripping
Tesco APC
Megs APC
Megs Degreaser
AG Degreaser
Virosol
Gunk
Blackfire Poly II clay
AS Tardis
Megs QD
Megs Pro mild / aggressive clay
Sonus Ultra Fine clay
Bilberry
Blackfire Gel Cleaner
BMW Alloy
R222 Gel
PB Sealant
Blackfire WD Metal sealant
FK 1000P
Gloss It Sig Tyre
Migliore Bella Lustre Tyre
Menzerna RD3.02 / 203S / 85RE / PO91L / 106FF / S34
Optimum Compound / Finish II / Polish II
Megs #205
3M Ultrafina SE
Poorboys SSR 1 / 2 / 2.5 / 3
Sonus SFX-1 / 2 / 3
Gloss It Evo Cut / Polish
Gloss It EVP Pad Prime
Gloss It 145mm pads
AG SRP
LC 140mm Pads
LC 100mm Pads
LC Wool purple / white
Menz 135mm Pads
Menz 80mm Pads
Sonus SFX Pads
LC CCS Pads
Porter Cable DA / Flexipad plates
Makita 9227 / 3M plates
Menz Top Inspection
Defelsko gauge
CL68 NSC / LLS
PB Blackhole
CK Vanilla Moose
Werkstat Prime Acrylic
Werkstat Prime Strong
Zaino Z2P
PB EX-P
AG EGP
Gloss It Concorso
Blackfire GEP
Blackfire Wet Diamond AFPP
Blackfire Midnight Sun
PB Nattys Blue
Werkstat Acylic Jett
R222 Carnauba
Dodo Juice Supernatural
Raceglaze 55
Collinite 915
Zymol Destiny
Gloss It Gloss Enhancer
Blackfire Deep Gloss
Poorboys QD+
Werkstat Acrylic Glos
303 Aerospace
NXT metal polish
Brilliant Restorer
Brillant Chrome + Hot enviroment
AG Fast Glass
AG Glass Polish
Raceglaze Leather cleaner / conditioner
Werkstat Satin Prot
Poorboys Natural Look
Gloss It TRV
+ stuff that I've forgotten and samples in the fridge. That's after I've sorted the chaff and given away stuff I'll never use again, I'm pretty sure I've used everything listed at least once in the last year. Compared to some DW collections, I'm only slightly odd.
