- 8 Nov 2006
- Ireland/Northern Ireland Border
On Ebay 1 quad core 3Ghz chip = 12Ghz
You don't make any sense whatsoever
ok sorry for my poor english
if cpu makers as in Intel or AMD, didn't start making multi-core cpu, as in dual core, tri-core or quad core or even six core and continue producing single core cpus.
then a 12 ghz cpu would be a reasonable standard for today.
my post reflect on my absolute personal opinion
No worries
No, because chip makers are hitting physical (heat/density) limitations on the standard transistor designs of CPUs, which is why they started thrashing out cores rather than eeking out more MHz
Probably worth also noting that even the "4 cars" analogy used in this thread isn't entirely applicable as those 4 cars are independent of each other while a multi-core system is not.
You may have 4 3Ghz cores, but you only have one set of transport links. Sure chipset manufacturers double things up and do clever scheduling etc., but it is still the case that one processors call for data at a specific memory location may be different to anothers and potentially they may do so at the same time, so this has to be managed at the hardware level. They all also have to send the data down the same set of physical pathways and mostly use the same sets of cache as a shared resource.
Multi-core processing is MUCH more complicated than most people imagine. Not only are there multiple cores trying to share singular resources from the hardware perspective, as others have said you also have to program to make efficient use of them. To go back to the 4 car thing, all 4 can't be driving at the same time if we only have one driver! So as programmers we need to intelligently split up the processing work into multiple "threads" of execution. That in itself has overhead. So even in a perfect hardware world where 4 cores means 4 totally independent computing systems that you somehow have instantaneous access to from the same operating system, the simple act of work splitting, scheduling and joining answers back together inevitably means you get less than the sum of your parts.
To give you an idea, lets assume we somehow have access to 32 cores, if my program was all processed using 1 thread this is our baseline (and in theory each core would be loaded at a little over 3% each). If we then split that out to 4 threads, we would not see an equivalent decrease in processing time, rather I would expect processing time to perhaps halve (at a guess) and like so many things, the process succumbs to the law of diminishing returns, so if we split out into 32 threads, we wont be 32x faster than with 1, we would be lucky to be 16x faster. At a certain point you would even start to become slower (assuming we keep our 1:1 mapping of cores to threads) as the overheads of splitting the work up becomes larger than the speed-ups gained by doing so.
Multi-threaded and cored computing has made things so so much more complicated
So to sum up, no I don't think its reasonable to claim a quad core 3Ghz chip is equal to a 12Ghz chip as it is mis-selling the chips capabilities on the most fundamental level.
Like I said it pretty much depends what your doing in the code. If a thread is running an in-memory calculation for most of the time and dumping the data back to the main thread after some time you will get pretty much the full speed. If your synching data back to the main thread on a regular basis you will induce waits while you pass the data back. If you making IO calls then again this will cause the thread to wait. All threads at some point will usually synch back to the main thread.
Writing multithreaded software can be very complicated and is a pain to debug because of the asynchronous nature of threads. Apps that might work fine on 4 cores can suddenly fall over with 8 cores.
All the software I write is multithreaded with some apps using 50+ threads.
We really need a new benchmark for measuring CPU performance because Mhz is meaningless anyway, overall FLOPS or something like that would be better.
Hi all,
A friend of mine has stated that because he has got himself a quad core processor running at 3 Ghz he now in theory has a 12 ghz o processing power, Is this correct? i was under the impression that he still only has 3Ghz of processing power but can run 4 processing threads at 3Ghz?
Thats like have a shot of 40% Vol whisky and saying its 80% Vol because you had a double instead of a single![]()
but its still gonna get you as drunk as a single shot of 80%?
+1 vote for single shot of 80% would be stronger...... wait i ment 12Ghtz
in the end you end up with the same amount of alcohol in your body no?
Sounds like he bought a prebuilt PC from the 'bay. I love the wording they use on there.![]()
