Afterburner fan profile for GTX 480 3 way
18 Jun 2005
Can somone post a pic of their afterburner fan profile for gtx 480. I assume people are using profiles to ramp the fan up earlier so it doesn't start screaming when temps get very high. It would be great if someone had a profile for 3 way 480's.
Here is a noise test I found. They are probably using stock profiles.
http://www.youtube.com/watch?v=R7jtEg3RcDA
Max temps 80c in crysis, max the fan hits at this temp is 75%, which is way quieter than the equivalent speed on a 5850/5870/5970.
Thanks for that Raven,
Yeah, I've noticed allright you can't really compare fan speeds on the GTX and ATI 5 series. I know when I had 5870's, anything above 40%-45% was LOUD. GTX's have to go much higher to reach the same dB level. Weirdly the 5970 4gig Sapphire cards go from 45% fan speed idle to 100% fan speed once the cards get to 50 degrees!!. Which is in every game of course. However the Acclero coolers on them even at 100% are still quieter then a 5870 at 40%. I've tried Afterburner and it does strange things with these fans, so use auto profiles currently.
Yeah I think the 480 fan is smaller than the ATI's, noticed you don't get the whoosh of air out the back of the card like with a 5870 at 50% fan speed, seems to be way lower RPM's on the 480 at anything but 90-100% speed.
I quite like the auto fan profiles. I had a toy around with custom profiles, but didn't find anything that I prefer (using dual-SLI 480s, but with no real gap between the first two cards).
The auto fan control ramps up only very gradually, so for the most part I get fairly quiet cards in-game, at around 80C with the fan at around 60-65%. In furmark the fan on the top board can reach 90%, with the GPU temp stabilising at around 91C. The auto-fan profile seems designed to stop the temps getting much above 90C, but aims for minimum fan speed below that.
Remember, radiative heat-loss scales with the fourth-power of temperature differential, so leaving the cards to become hotter before you ramp up the fan speed is the optimal way to minimise noise (the larger the delta, the more energy is extracted from the heatsink for a given airflow). Of course, this means your everyday operating temperature is likely to be higher than using a fan profile such as the one raven is using, but to my mind if the card is designed to operate at high temperatures, then I see no reason to kill myself to reduce them.
Also, remember that a given fan speed and a given GPU load will rapidly lead to a stabilised GPU temperature. For a given GPU load, ramping up the fan earlier does not alter this stabilised temperature - it simply increases the time it takes for this stabilised temperature to be reached. Basic thermodynamics...
...In short: A good approach would be to consider what is a 'comfortable' fan volume while gaming, and have the fans run at around this level from base gaming temps (say ~70C) until the GPU temperature gets unacceptably high (which is around 90C, based on nvidia's stock profile). Once you reach this level, have the fans ramp up fairly rapidly (say within 5C they should be at maximum), so that you can maintain a roughly constant temperature without using too much fan unnecessarily.
I'm thinking of moving back to 3 way GTX 480 plus 9800gt for physx. Last few days with 10.8 ATI driver issues have been driving me mad. I can't take it anymore. My hair has actually started falling out (what's left of it). Never gave Nvidia a chance over the noise. The lousy Corsair AX1200 I have now isn't helping matters either.
Glad to help guys :)
No love for the AX1200?! Mine is ace... Amazing power stability, and it stays nice and quiet even at full power. I suppose I only have two GPUs on the go, but I guess the total power draw won't be too different to your quad-fire setup, given how power hungry the GTXs are.
Well, I say it stays nice and quiet - I guess it could just be getting drowned out by the GPU fans :p [just checked in furmark, putting my ear right to the PSU - seems to still be fairly quiet...]
Flanno - I should point out that I'm using a HAF-X case, with a 120mm fan in the GPU fan duct, so it blows cool air directly into the GPU intake ducts. I think this helps to keep noise down in the top GPU a little...
If you bought your AX1200 from OCUK you got lucky.
Here is what I think of it.
http://forums.overclockers.co.uk/showthread.php?t=18183495
:mad:
Ouch... Yeah, that would annoy the hell out of me as well, particularly given that it's such a high-end part.
And no, I didn't get mine from OcUK. I found it cheaper elsewhere. Having dealt with the customer service at this other place in trying to get my H70 returned, I'm very glad the PSU has worked out!
With your PC turned off, is there an electrical chirping noise from the back of yours PSU ? I have gone through 3 AX1200's now (2 from OCUK) with this trait. When you play a game / run a benchmark the coils go mad and this chripin coming out the back turns into a vicious buzzing noise. I've spoken with Redbeard from Corsair and this PSU should be quiet up until 600 watts. After that the fan ramps up and it's not the best quality fan so is slightly noisy compared to the one in the HX1000 (at least the reviews have said so).
Nah, I guess I got lucky. It's completely silent when the PC is powered down.
As for the fan noise, I couldn't hear it over the GPU fans even when I had my ear right to it. But then, it IS pretty near to the GPU fans, and they're fairly loud if I load them enough to shift more than 600W. Kind of a moot point for now I guess, but if I move to watercooling it will be the only non-silent fan in the case, so it'll be more of an issue.
