- 20 Jun 2004
- Essex
What's the cheapest one you can find me please?!
Best i've seen is £4.40!
IMO so long as the cable is well built, it'll be fine.
Any decent quality 5m HDMI cable will do, there is no such thing as "HDMI 1.4 cable". There is Certified Category 1 and Category 2 cable, anything else is marketing speak/branding. The key word is certified, just because a £1 cable isn't certified, doesn't mean it wont do what you ask it to.
yeah there is, hdmi 1.4 requires different cables to enable ethernet over hdmi. you are right there there are two different grades (standard and high speed) but they are still different cables to < hdmi 1.4 in that with previous hdmi versions the pins used for ethernet arent connected and probably no cables that arent 1.4 certified have wires connected to those pins either.
So, my 2 new 5m 1.4 cables arrived- £4.40 each and not too bad quality build as well, reasonably chunky but obviously just plain black plastic.
