TODAY ONLY DEALS - 08/09/2010
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
Today we have one of our best selling coolers and our all time best selling case at great today only deals prices. Free shippping is available on these for the forum members :)
Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM3) @ £32.98 inc VAT
Venom, this cooler is definitely rock and roll. Venom delivers ultra high performance enabling serious system overclocking. The 12cm killer Viper yellow fan uses S-Flow blades providing 30% more airflow than a standard fan at the same speed. PWM function ensures quiet operation during normal system use and performance cooling under load.
The Black cover and nickel plated heatpipes combined with the Viper yellow elements creates a striking combination which adds pazazz to any system. Four high capacity 8mm heatpipes with direct CPU contact provide rapid heat transfer from CPU to 45 aluminium fins. Anti-vibration rubber fan mounting pins provide easy installation and help to elimate a lot of fan noise. Adjustable mountings ensure full compatibility with all current AMD and Intel CPU’s.
The Smart cooler design allows for the installation of a second fan, giving extreme performance in a push-pull setup where the first fan “pushes” air through the heatsink’s cooling fins, at the same time the second one “pulls” air through from the other side. The combined airflow of two 12cm fans results in more efficient heat dissipation and consequently lower CPU temperatures.
- Dimensions: 120 (W) x 96 (D) x 160 (H) mm
- Fan speed: 600-1900 RPM (PWM controlled)
- Max airflow: 83.63 CFM
- Noise level: 6.9 - 28.9 dB(A)
- Performance 12cm PWM fan in killer Viper yellow
- 4 high capacity 8mm heatpipes with direct CPU contact
- Award winning S-FLOW fan blades provide 30% more airflow
- Smart design allows for a 2nd fan for extreme performance
- Rubber fan mounts for easy installation and quiet performance
Only £32.98 inc VAT.
ORDER NOW
Antec 902 Nine Hundred Two Ultimate Gaming Case - Black @ £76.36 inc VAT
Antec’s popular and award-winning Nine Hundred gaming case became an instant favorite among gamers, delivering versatility, style and performance to establish itself as “The Ultimate Gaming Case.” Now Antec introduces the Nine Hundred Two, the next generation in premier gaming enclosures. Building on the tried-and-true designs of both the Nine Hundred and the powerful Twelve Hundred gaming cases, the Nine Hundred Two maintains popular features such as a perforated front panel, up to six variable-speed fans for maximum cooling, and a sleek, aggressive aesthetic. The Nine Hundred Two adds exciting improvements such as a top 200mm Big Boy TriCool™ fan now with blue LED, fan control knobs plus built-in washable air filters right in the front panel, and eight expansion slots for even greater versatility. Dominate your competition and maximize cool with the Antec Nine Hundred Two: “The Ultimate Gaming Case, Evolved.”
- 9 drive bays
- External 3 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 3 x 3.5" for HDD, or
- External 9 x 5.25"
- Advanced cooling system:
- 1 rear 120 x 25mm TriCool™ blue LED exhaust fan
- 1 top 200 x 30mm “Big Boy” TriCool™ blue LED exhaust fan
- 2 front 120 x 25mm special black blue LED intake fans with front speed control
- 1 side (Optional) 120 x 25mm fan mount
- 1 middle (Optional) 120mm fan mount
- Built-in washable air filters
- 8 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Front mounted I/O ports
- 2 x USB 2.0
- 1 x eSATA
- Audio In and Out (AC’97 and HDA compatible)
- Motherboard: Mini-ITX, microATX, Standard ATX
- No power supply included
Only £76.36 inc VAT.
ORDER NOW
