i7 [email protected] with H70. Would W/C be a worthwhile upg?
that's very good, I wouldn't bother with a custom water setup as that's only 2-3C more than I get with a i7 920 @ 4GHz, EK supreme HF and a 420 rad
The only reason u would want to switch to custom water for really is to have those sorta temps and quite running fans. Or if you wanted a new challenge, thats why most go water cooling from what iv seem, to try something new.
Now with that being said, it really all depends on how much vcore is required for certain clocks, you may be lucky and not need a lot more, or u may be unlucky and need a lot more.
Yep getting good temps, only way to see how much extra heat you get from the chip is by actually trying it out yourself, always going for the minimum vcore and vtt/qpi possible.
