hi Eqaulizer
seems that most of the posts in here are correct.
if money is no object then perhaps consider the megahalem with a pair of good fans.
the noctua d14 is good but limits the taller kits of ram
the H70 is a safe bet but costs a lot for what it is.
the fenrir and Gelid tranquillo are excellent but if you have a bit more to spend then the megahalem will see you right
