Spec me a new internet provider
27 Oct 2006
London
Fed up of Virgin and their lies. They took a perfectly good service called Telewest and tore it apart.
I've cancelled after being cable for 10 years.
A new BT line will be installed soon but which ADSL/2 provider should I go for ?
What about BT Infinity which is apparently coming to my exchange at the end of the month ?
Any help on value for money ADSL would be great guys
Gives me this mate....
BT Wholesale ADSL
BT Wholesale ADSL Max
BT Wholesale WBC (21CN)
BT Wholesale SDSL
AOL LLU
O2 / Be LLU
Bulldog LLU
TalkTalk (CPW) LLU
Sky Broadband / Easynet LLU
Tiscali LLU
Tiscali TV (via Tiscali LLU)
Orange LLU (Formerly Wanadoo)
Virgin Media (Cable)
Well ADSL depends on your line; condition and length.
But O2 / Be LLU are your best ISP for ADSL2+ unless you look at VDSL(FTTC)
EDIT:
You are approximately 1.21km from the exchange. Note that this is the straight line distance - the actual cable length will be longer!
Yeah VDSL will be available at the end of the month which ironically is the same day Virgin is disconnected :)
So I'm in a pickle ADSL or wait for VDSL ? :/
EDIT:
link I would wait for vdsl But i'm not sure you can go with anybody but bt to begin with at least, but i could be wrong. Also I wouldn't depend on that date.
Yeah I've been a bit dumb. Seems like sam actually does know and has all the information in one place. They've changed the site a lot since I last visited :D
Thanks for the help mate
Yeah with regards to BT fibre it says ...
FTTC should be available in your area from 01/12/2010
Downstream Min: 18.8 Mbps
Downstream Max: 33.1 Mbps
Upstream Min: 8.5 Mbps
Upstream Max: 14.9 Mbps
- I might just go with ADSL2 tbh - I'm not a big downloader ;)
