What's the name of that free Virtual Machine software?
11 Jun 2004
Middlesex, London
Hi all,
There is a free virtual machine application available
Called 'open....'?? or 'box...'?
can anyine suggest or recommend?
Thanks
Use Virtualbox (was from Sun, now Oracle) at work a lot for running Linux VM's under Windows. VMWare Player is another tool which does the same sort of thing. Both are free.
That's assuming you want to virtualise under an existing OS instead of installing a bare-metal hypervisor.
There's loads VMWare Player, VirtualBox, Microsoft Virtual PC, the list goes on. Personally I recommend VirtualBox and VMWare Player, as they support 64-bit VMs (for some reason Microsoft didn't when I tried it).
Virtual PC doesn't seem to like Linux! I wonder why? :P
Sure there is a work around but it's easier to use Virtualbox.
I've tried Virtual PC, Virtualbox and VMWare Player. In my experience, in terms of performance, Virtual PC is the poorest and VMWare is by far the best.
I'm running mint 9 in Virtual mode in Oracle VirtualBox, and I haven't run into any problems.:D
Don't forget to check out phpvirtualbox. It's the dogs ******** if you want quick access to the VirtualBox control panel.
