New SATA HDD for laptop is recognised in BIOS but wont allow windows install
1 Dec 2004
S.Wales
Basically iv been given a laptop to sort out, you could tell at first check the SATA HDD had gone, it was making a whining noise and clicking, so I chucked the HDD in my PC using a converter and it done exactly the same thing.
I ordered a new HDD which I have recieved, its a Western Digital 160 GB SATA Laptop HDD, installed in to laptop, booted xp install disk and although the disk was recognised in the BIOS, on windows installation it said it couldnt find any hard disk drives.
Anyway, i put it in my other laptop (as my laptop has a spare hdd slot) and booted) logged in to windows, it didnt see the drive straight away but could see it in disk management as unassigned, so I created an NTFS volume and formatted it, I could then see the disk in my computer.
Put the drive back in the other laptop im trying to install windows on and the windows installation still cant see any hdd's but I can see it fine in the BIOS, anyone got any ideas? :(
Its a gateway laptop (yuk) is there anyway you can manually load drivers for the installation?, strange iv never seen this issue before :S
Surely if I have used this install disk before to install XP on a SATA HDD it should work :\
Is it an XP disc with SP3 slipstreamed?
Nah its an XP disk with SP2 on, im sure SP3 slipstreamed will make it work, is it just a case of downloading sp3 and slipstreaming it with the installation disk I have using nlite ?
Sorry, this is vague. When I first used a SATA drive, I had a bit of bother with this. IIRC, when XP installer first starts to load, the bottom line of text said something like "If you have SATA drivers on a floppy, press {key} now".
Tried slipstreaming some SATA drivers for the mobile devices from intel, it gets past the not recognising HDD bit on the XP installation but after it copies over files and does the install, it re-boots then blue screens.
When I slipstreamed the drivers I downloaded the standard SATA drivers from Intel which containted a zip file with multiple drivers, i added all the mobile drivers in, im guessing what is happening is its conflicting so i need to find exactly which driver I need, however im having trouble finding any info on the web including gateways website.
The model number of the laptop is ML6226B
Does the machine have an option in the BIOS to switch it it AHCI mode on the SATA controller?
It doesnt no :( its a very basic BIOS, i have though found a website which lists its intel chipset type - Intel 943GML, had a browse on google but not finding much, iv had one or two possible results and have slipstreamed them ready to test later.
Trying to work out what SATA controller the above chipset uses.
