thanks for the replys.
The hard drive is overheating big time but would this shut the laptop off completly??
Yup. Had a very similar issue with one of my older laptops recently. Took it apart and the heatsink was almost completely clogged with dust. They can be a pain to dismantle but think it's worth checking. As well as using the fan as a clue (good tip above) does it shut down after a certain time or when you are running anything particularly CPU intensive? These can be signs of overheating also.layer of "dust/fibre carpet" over the inside edge of the heatsink.
