Hey guys,
Just been ripping the old council wallpaper off my walls ready to put lining paper up, then paint. When I ripped the paper off in the corner of the room and above the chimney breast, there was damp plaster and what looks like salt residue. The plaster behind the skimmed area has white powdery substance present and the plaster is coming away in areas.
There has been a damp patch on the plaster ceiling next to the chimney breast for years, it never gets any bigger but keeps coming through the paint. I believe the council remedied this and it was something leaking on the chimney stack. But I didn't know there was damp on the walls.
Been up in the loft and had a good look around and the chimney stack is bone dry with no signs of any damp.
The strange thing is that the wall with the big damp patch on stops in the loft and the bricks are visible from above and are dry. So water cant be soaking down
. I just cant work out why its there or where its coming from.
Also, its the same in the next room, there is an airing cupboard and the paint is all shrivelled and flaking off.
tl;dr - walls damp yet bone dry above...wtf?
Anyone got any ideas?
