- 29 Oct 2002
- London
hi there
Im currently using three Linksys by Cisco WAP54G access points to get wireless to this care home down the road.
they work great individually (3 SSID's broadcasting) and can be set to "repeater" mode which is essentially a wireless range extender (to merge all access oints to one SSID) - the downside is that this mode severely reduces the bandwidth as the access points must communicate with each other via wireless too. (why cant you buy range extenders that communicate with the acccess point/router via ethernet cable so it doesnt degrade the wifi signal???)
can anyone recommend a wireless setup or even a range extender than is a better option? or do they all increase range but reduce bandwidth?
the problem is that in a few of the rooms no signal at all goes through the walls so a convential range extender (that amplifies a weak wifi signal) will not work.
can anyone put me straight? can i pay more money for more professional equipment?
edit: all rooms have an ethernet socket btw.
we all have to start somewhere. Post back with how you get on.
