I'm still on 1.6.1 (not got round to installing 2.00 yet).
But on 1.6.1 it's an absolute value.
I need 1.087V for 850/1700, which is 30mins OCCT error free.
Mem @ 4.2GHz.
Interesting.... Yours is showing an absolute value. My guess is that the voltage regulators must be different between the Cyclone and the Hawk! As mine shows an offset! And there is a comment in the Afterburner manual:
"Depending on graphics card model the voltage can be
represented either explicitly or as an offset added to base voltage. Singed values represented the offset whilst unsigned values represent absolute voltage"
And the only reason that I can think of for the difference, is that for some cards, the software can't read the voltage and hence can't display it as an absolute value! Could be another explanation of course.
Though seems a bit daft to me, with the Hawk supposed to be the top knob MSI 460 card (so to speak).
If I make my offset +60mV to 1.025V, then that gives 1.085V to get to the same OC as you. So I'm thinking that there isn't "that" much difference between the Cyclone and the Hawk version of this card. Obviously as my stock voltage is higher than the Cyclone, it does mean I could ultimately put more voltage through the GPU.
IE. 1.025 + 100mV = 1.125... slightly higher than the 1.087 that I've seen quoted a few times as the max voltage.
I'll try +60mV and test again.
So being totally objective. I can't really see the point in paying the premium for the Hawk version of this card over the Cyclone (some £35+ difference) ... unless you want to really push the OC, or like me, you just fancy one.
