My inflatable bed is deflating!
18 Jan 2007
Land of the Scots
Sooo... Due to current circumstances I am sleeping on an inflatable bed every night and it seems to have come to the end of it's life as it's 60% deflated by morning... Not very comfy...
Before I go out and buy another one does anyone have any tips on finding any possible leaks? I did try and get it in the bath to see the bubbles coming out but that didn't work, was thinking about maybe taking it to the park and stick it in the pond.*
*Not serious.
Stop sleep humping and pushing the air out.
Seriously though - if it's leaking really slowly then it's either a crap valve or there's a tiny hole or two somewhere. It's probably best to try and get a new one rather than faffing around sticking it in the bath.
As said, probably the valve but sounds like it could just be when it has some weight on the bed that it's letting anything out (higher pressure).
What ever you do. Do it knowing that tonight, I will be in my fully made bed all cosey and warm, with no worry what so ever that my bed may deflate.
If you can find the puncture easy. Fill a squirty spray bottle or water container with a little fairty liquid added bubble will appear near punture. Just go slow and methodical. Dont add more than a small bit of washing up fluid you will just get bubbles everywhere. We do this to find small puncture in tyres at work without talking wheel off then plug it..
