- 17 Apr 2006
- Hampshire
Hi All,
So I'm pretty sure I want to go water cooling. Mainly because I'm sick of having to buy new coolers all the bloody time. I just want a kick ass cooling system I can strap onto anything for the next 5 years rather than collecting defunct coolers. I count at least 3 gpu coolers I'm not using and 2 cpu coolers I've given away in the last 3 years alone.
I'm in an MATX case currently on socket 775 but with a view to upgrade the socket in '11. The case is modded to allow 2x140mm fans (with 120mm mounts) to be in and out. I'd like to do a loop with:
Pump
DB1
Blocks
XSPC XP20
XSPC Delta V3 CPU
Rads
2x SR1s 140 (one for back and one for front)
Res
XSPC Single Bay Reservoir
Tubing
8mm ID silicone tubing in blue
Thoughts?
Cheers,
Chris.
Pump
DB1
Blocks
XSPC XP20
XSPC Delta V3 CPU
Rads
Res
Tubing
Thoughts?
Cheers,
Chris.
